gixxerman600 Posted May 22, 2008 Share Posted May 22, 2008 Rad leak were the ac line goes in under filler cap. Its not loose but leaks. Do any of you great guys have a fix for me? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 22, 2008 Share Posted May 22, 2008 Rad leak were the ac line goes in under filler cap. Its not loose but leaks. Do any of you great guys have a fix for me? Are you referring to the tranny coolany line flare fitting? Try this: Remove the flare nut, tighten the big 15/16" bulkhead nut that holds the flare fitting to the rad, wrap the flare fitting threads with teflon tape, and hook the tranny line back up. Worked for me....... Link to comment Share on other sites More sharing options...
BLHTAZ Posted May 22, 2008 Share Posted May 22, 2008 If you have coolant leaking there...it's time for a new radiator most likely. Link to comment Share on other sites More sharing options...
