Eagle Posted May 19, 2008 Posted May 19, 2008 I can't find the thread in which someone asked about manual steering boxes with a faster ratio than stock. I was searching for something else tonight, and I found that NEW Saginaw 525 boxes are being manufactured right up the road from me. And they offer the 16:1 quick ratio I remember from my autocross days. Shed some weight! Borgeson offers a way for you to shed some weight off your GM muscle car, up to 28 pounds! These are complete kits that convert your car from power to manual steering in the matter of a couple of hours. Think about it, no more power steering pump robbing your motor of those much-needed hps to make you more competitive. No more power steering fluid to deal with and no more power steering hoses to inspect. The power box in your car now can be up to 30+ years old, worn and tired. Replace it with a brand new 525 box and make your steering more responsive. We have kits for the following applications: 78-88 Malibu and the 82-92 Camaro part number 999001, 64-72 Chevelle, 442 & GTO part number 999002 and 70-81 Camaro, 75-79 Nova part number 999003. These kits include a brand new 525 box, pitman arm and rag-joint. The 525 box is the ONLY box GM recommends for these applications. The vega (140) box is too light duty for these applications, the vega box is only recommended for cars weighing less than 2500 pounds. The 525 use the same mounting configuration as your power box so mounting it is a breeze. The pitman arm is designed to replace the existing pitman arm in length and bend so all your clearances remain the same and the rag-joint will bolt right onto the 525 box and the column end. The 525 box comes in standard 22:1 ratio for the best overall drivability, we also offer a quick ratio 16:1 525 box for competition. All these kits have a five year unlimited mileage warranty. For any technical or ordering information, please call 860-482-8283. Borgeson Universal Company / Mullins Steering Gears, 91 Technology Park Drive, Torrington, CT 06790, www.borgeson.com
