Imperial21 Posted May 17, 2008 Share Posted May 17, 2008 are cherokee and comanche spring plates the same? I've got a 91 LWB 4WD. I broke a stud on one and the other side is bent(thanks to PO for putting wrong shocks on :mad: ). There are no 'manches in the boneyard here but two pretty good cherokees. :Canadaflag: Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 17, 2008 Share Posted May 17, 2008 XJ's don't have the stud for the shocks as the shock mounts are directly on the axle. The MJ's have the studs as the shocks mount to the spring plates. So to answer your question, no they are different. Link to comment Share on other sites More sharing options...
Imperial21 Posted May 17, 2008 Author Share Posted May 17, 2008 crap! :mad: thanks for answering! guess I'll cut out the studs and put the bigger mopar ones in. :Canadaflag: Link to comment Share on other sites More sharing options...
jackel18 Posted May 18, 2008 Share Posted May 18, 2008 i bought CJ spring plates to replace mine, they have the shock studs attached Link to comment Share on other sites More sharing options...
