jpdriver1 Posted May 9, 2008 Share Posted May 9, 2008 hey guys --- when I turn up the speed on the blower motor, the volt guage dips to the low side. which is more likely bad switch or bad motor ? 1990 mj thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 9, 2008 Share Posted May 9, 2008 hey guys --- when I turn up the speed on the blower motor, the volt guage dips to the low side. which is more likely bad switch or bad motor ? 1990 mj thanks Could be either or most likely a partially shorted resistor pack that drops the voltage for the blower speed control. Best way to start is to disco the motor connector and temp hook it directly to the battery. If it runs well on high speed, it's most likely the resistor pack, about $24 at Rock Auto. These go bad often. http://www.rockauto.com/catalog/raframecatalog.php?carcode=1180156&parttype=6557&a=FRc1180156k1140277 Link to comment Share on other sites More sharing options...
jpdriver1 Posted May 10, 2008 Author Share Posted May 10, 2008 great thanks --- I'll try this weekend Link to comment Share on other sites More sharing options...
