E-brake handle from Cherokee console
I asume all Comanches have foot operated e-brake. Will the console mounted e-brake work on Comanche? Even if some minor mods are needed?
just need to figure out how to make a stub cable between the handle and the rear cables, OR use the cherokee ebrake cable system, or both.
it would need some custom work. installing the handle itself won't be hard. connecting it to the rear cables is going to be the hard part.
If you take the e brake hande and associated bracket form under a XJ, it should be an easy retrofit. Basically you need to make the section that goes from the center of the cab to where the ebrake cables come off the axles.
