vwdieseljunkie Posted May 10, 2006 Posted May 10, 2006 Does anyone know of a suitable DTC's that could be used to dump on the driver's side? When I rebuild/duplicate my mercejeep, I definately want to go 4x4 while it's in the building stages. Luckily, the mercedes tranny is fairly short from bell housing to output. I will just have to have an input yoke made for the TC (or tranny).
pingpong Posted May 11, 2006 Posted May 11, 2006 Ford has the divorced 205. stout transfer case. gear to gear with cast iron case. many upgrades are available for this, weka points are the output shafts. I also think lower gears are available, but thge popular thing to do is run dual cases using a 203 as a range box. Then there are the rockwell t-case. way heavy, and I don't know much about them. Patrick
