maddzz1 Posted April 15, 2008 Share Posted April 15, 2008 Which bolts do you use it on? and which color? Link to comment Share on other sites More sharing options...
mjeff87 Posted April 15, 2008 Share Posted April 15, 2008 use it on most any fastener you want to ensure stays fastened. Blue if you want to be able to take it apart at some point down the road, red if you don't plan on ever taking it apart again. Jeff Link to comment Share on other sites More sharing options...
maddzz1 Posted April 15, 2008 Author Share Posted April 15, 2008 I plan on using the blue on my valve cover bolts when I replace the gasket; will it be OK to use with the heat from the block? Link to comment Share on other sites More sharing options...
