Cabz Posted May 7, 2006 Share Posted May 7, 2006 My rear brakes are lockin up Big time :eek: , It does not matter where I put the laod sensor valve arm they still lock up nicely when I have to stop quickly, Any one have any idea on what I can do to correct this? Preferably cheaply :D Link to comment Share on other sites More sharing options...
Eagle Posted May 7, 2006 Share Posted May 7, 2006 Bypass the load sensing valve and install a Wilwood adjustable proportioning valve from Summit Racing. Take the two lines to the rear from the front combo valve and tee them together somewhere in front of the gas tank, then run just one line from there through the Wilwood valve directly to the rear axle brake hose. You can also get an adjustable proportioning valve from dealers. It's in the Mopar Performance Catalog, and is probably a Wilwood in a DaimlerChrysler package. Link to comment Share on other sites More sharing options...
