maddzz1 Posted April 9, 2008 Share Posted April 9, 2008 Has anybody used por-15 on the inside bottom of there doors? Is there a drain hole in the bottom of the door incase water gets in there? Ive had 2 cars where the support for the window rotted and came loose. Link to comment Share on other sites More sharing options...
jaekl Posted April 9, 2008 Share Posted April 9, 2008 The drain holes are at least 1/2 inch. They're not like the old slots that used to be used and easily clogged. If you used POR just make sure the holes are open but it shouldn't bridge across. Are the rotted supports the cables that run the window up/down? Somehow water can puddle in the bottom of the doors and the end of the cables are there. Once water gets into the rubber hose where the cable sits, rust starts. There must be a way to keep the end of the hose dry. Link to comment Share on other sites More sharing options...
