Very High Idle
Hi all. Haven't had much issues with the jeep until just recently. Sometimes when I start it the idle will go up to around 3000 and stay there. It goes away after I drive for a minute, but if I turn it off and restart it it does the same thing. Any ideas what might be causing this?
Chris
there has been some info IRT to Hi Idle if you do a search :brows: my problem was with the EGR valve needed replacement and the problem went away. do some research on this site so that you'll additional inforamtion to go by jamminz.gif
A couple of things could cause this.
Bad Throttle Position Sensor
A vaccum leak
My 2.5 is doing that right now, it has a bad intake/exhaust gasket
On a 4.0 the throttle body might need cleaned
(IAS)Idle Air Speed motor on 2.5 and (IAC)Idle Air Control on 4.0
There are other possiblities but these are probably the most common
