shock question?
Go to the Monroe shocks on-line catalog. At the back they have a spec section that shows the mounting configurations, lengths, and travel dimensions for every shock they make. You can look up the stock shocks for a TJ and an MJ in the application listings and then compare dimensions.
I don't think TJ shocks translate very well into the MJ, but that's based on fuzzy memory.
I was pretty sure a TJ coil didn't lift a XJ/MJ as much. If so the shocks will be the same. OH, they will fit just fine, just not provide as much lift.
Conversely, YJ shocks offer about 2" longer length than a XJ/MJ. SO a factory YJ shock should do what you need.
CW
