wranglercory Posted February 25, 2008 Share Posted February 25, 2008 I just got started working on my 89 MJ I would like to know if I can safely remove all of the vacume lines attached to the air box. I realize that I can't remove the lines going to the valve cover, but what about all of the other lines like the one going to what looks like a warm air valve on the front of the air box, and the lines going to something at the intake mani. This will be quite a work in progress but I am so excited that I finally goto my MJ :D Link to comment Share on other sites More sharing options...
Randy in Maine Posted February 26, 2008 Share Posted February 26, 2008 Why are you removing them? If it is to replace them with fresh hoses that is OK to do. Link to comment Share on other sites More sharing options...
brandonmcnulty Posted February 26, 2008 Share Posted February 26, 2008 Personally i unhooked every one of those vacuum lines on top of the engine, the only one left is the skinny one that runs from the back of my valve cover to the air box. i know this may not be right but ive put about 15K on it since ive bought it with no problems at all. plus all the blow by just blows out the top of my engine and stays out of my air filter. Link to comment Share on other sites More sharing options...
Randy in Maine Posted February 26, 2008 Share Posted February 26, 2008 I will defer to others (as I am more used to other FI systems) but wouldn't that vacuum loss pose a problem for the fuel pressure regualtor and make it run rich? Link to comment Share on other sites More sharing options...
wranglercory Posted February 28, 2008 Author Share Posted February 28, 2008 I am just talking about the vacume mess that runs the vacume valve on the front of the airbox. Also what are the vacume parts attached to the side of the intake, that is one part I'm not familure with . Link to comment Share on other sites More sharing options...
tjbliley Posted February 28, 2008 Share Posted February 28, 2008 You are talking about the EGR and pre-heated air intake. The valve on the front of the box draws air from the dryer vent looking hose attached to the area under the manifold. The one on the side of the manifold is the EGR. That recirculates exhaust gas based on the premise that it contains unburnt fuel until the motor heats up. Link to comment Share on other sites More sharing options...
