Axle move.
With the RE. 5 1/2" short arm lift I couldn't get enough caster in the front
ant the tire's where pull'd back in the wheel well's so out came the welder and add'd about 2 1/2 -3" to the arm's.
For the lower's I cut and sleave'd the RE. arm's with some 1 3/4" dom tube.
The upper's I had some RE. grand cherokee rear upper's that I lenghten'd an change'd the axle end giving me a flex joint on both upper and lower arm's.
The new upper's. I did add more lenght to these after the pic.
The new lower's.
With 33" claw's before th move.
After the move.
With 33" claw's on 15x10 's
