ridenlow12 Posted February 14, 2008 Share Posted February 14, 2008 Hey guys I want to strip the automatic set up out of my parts rig before it heads to the scrapper. other than my list below what else do I need to get out of it to replace my 4spd? Transmission/bell housing if it has one torque converter colum shift linkages speedo cable pedals Link to comment Share on other sites More sharing options...
Geonovast Posted February 14, 2008 Share Posted February 14, 2008 Tranny cooler lines, TCU which should be under the dash. Flexplate Just get a floor shift kit out of an XJ :D Link to comment Share on other sites More sharing options...
Eagle Posted February 15, 2008 Share Posted February 15, 2008 If he's replacing a 4-speed manual tranny, it's a 4-cylinder MJ. I don't believe the Chrysler tranny for those used a TCU, so the list looks pretty okay. I second the idea of using an XJ floor shift rather than trying to use the MJ column linkage. There's a cable in there to operate the PRNDL, which is in the dash cluster, so to do the column shift right you'll have to find a gauge cluster with the PRNDL. Good luck -- it wasn't used in the XJ. Link to comment Share on other sites More sharing options...
