89Tonto Posted April 15, 2006 Share Posted April 15, 2006 I would like to get my CC working since it has never worked in the past. Could it be as simple as replacing the brain box/module? I was told that there are different colored boxes. Mine is yellow. Therefore, I would need to find a yellow one to see if that works. Too simple? :roll: Any better suggestions. Thanks, Scott Link to comment Share on other sites More sharing options...
87manche Posted April 15, 2006 Share Posted April 15, 2006 pull the yelow box apart and see if there's any obvious burns. Also, the motor on the throttle body is vacuum controlled. Look into that also. Link to comment Share on other sites More sharing options...
