Comanche Specific Lift Items - SE Louisiana
Tex06
Can ship on buyer's dime but would prefer to sell all together if possible.
Core 4x4 adjustable control arms set (Tier 1, about 4 years old Now called their "Cruise Series") - $180
Rough Country control arm drop brackets and hardware- $60
4" lift coils (Old Man Emu, ran for 3 months... they still have the tags on them) - $130
4" rear springs (unknown manufacturer... they're 4 leaf and ride well) - $200
5x4.5 to 5x5 wheel adapters (so you can run newer wheels) - $100
4" Alcan Rear Springs (Used less than 1 month; True 4" lift on 4x4, closer to 5.5" on 2wd) - $700
AX-15 4x4 crossmember (fits 91-92 MJ, 91-01 XJ) - $250
Control Arms, drop brackets, crossmember, and wheel adapters
Picture of my truck with Alcan and OME springs plus Core arms and drop brackets with 31" tires
Alcan 4" springs in foreground (1250lbs/in). Newer 6" lift behind it (1300lbs/in). 8 leafs/spring.
Tag on the OME 4" coil springs.
Lift on the 4" OME coils. Bucket to body is right at 15.5" (with a 4.0)
Lift with the Alcan springs 11.75" from frame to axle tube. (I *think* this is the 4" ones, I will  confirm)Spring rate is 1250lbs/in which gives a *very* comfortable ride with an empty truck or about 500lbs in the bed.
Drop brackets and control arms right before removal from the truck.
Another shot of the drop bracket.
  • Tex06 changed the title to Comanche Specific Lift Items - SE Louisiana
Archived
