ktmall07 Posted 2 hours ago Share Posted 2 hours ago Hi all, I recently completed an 8.8 swap, and installed a rusty's 3" lift front and rear at the same time, and have since had some driveline vibrations at high speeds (> 55 mph). I've narrowed the vibrations down to the rear driveshaft, and checked u-joints first (both were replaced on installing the new axle, and seem fine, they're a few months old). The new 8.8 flange adapter is in good shape as well, it was brand new when purchased, and nothing on that end is loose/worn. I did not install a slip yoke eliminator, because my lift height is not extreme, and pinion/t-case angles are close enough to have almost no slow-speed angle-related vibrations. When inspecting the slip yoke, it seems that pushing up on the driveshaft right below the u-joint causes the transfer case output shaft to move just a hair (< 1/8", just enough to be noticeable). The movement is only up/down, not side-to-side, no matter the position of the u-joint/drive shaft. Maybe the lift itself has put just enough pressure on the bottom of the output shaft to bend something? My question is: Is any amount of lateral movement in the output shaft normal? I've read that excessive movement could mean a worn tailhousing bushing/seal? There's no real leak from the tailhousing (or the transfer case generally), so not sure if either of those things being worn would be noticeable enough to diagnose without pulling it apart. I also haven't taken off the slip yoke since I reinstalled it. I can't tell if the movement is from the output shaft itself or the slip yoke, but it seems like the movement is from the output shaft (when pulling in different directions, I can't move the slip yoke at all, there's no play in it on the end of the output shaft I don't think). If I have to take everything apart to check anyways, Is an SYE necessary/worth it? I thought I was good without one since the lift was not extreme, but maybe better safe than sorry? Any input would be appreciated. Thanks! Link to comment Share on other sites More sharing options...
