'88 Comanche 4.0 (w/Dana 44) - Melbourne, FL (32905) - $500
dkenitz
***price drop: 500
For sale is a 1988 Jeep Comanche 4.0 (2wd) w/5-speed BA10 transmission and rare Dana 44 rear end option (see pics). Owned for ~7 years, used to move into current home and was parked at that time as brakes basically failed pulling into the driveway after a load.
Recent maintenance/work: new clutch, pressure plate, slave cylinder (internal), water pump, t-stat, radiator. Comes with LOTS of parts, including rear window seal in good condition, fuel sending unit in good condition, new headliner, etc. Needs fuel tank replaced (included) due to rust, brake work all around, tires, driver's side floorboard has some rot, etc.
Dustin
Some parts pics...includes full-sensor style gauge cluster, brand new gas tank, new headliner purchased on forum, also should have a set of nice condition tail lights in the attic.
  • dkenitz changed the title to '88 Comanche 4.0 (w/Dana 44) - Melbourne, FL (32905) - $750
Wow...  surprised no one has jumped on this deal.  Have you posted this to the MJ Facebook groups yet?  The additional visibility might help.
Also, constructively, it's unclear from your ad if the truck is actually running after the recent maintenance.  Looks like you serviced the cooling system and trans. Is the old fuel system still connected? Maybe clarify if the truck runs and can move under it's own power.
Your asking price is very reasonable.  One could even argue it's too low considering the D44 alone goes for $300-600.  If it runs, I'd say throw it on FB for $1500 and let some guy low ball you at $1000.
  • dkenitz changed the title to '88 Comanche 4.0 (w/Dana 44) - Melbourne, FL (32905) - $500
Appreciate the advice! It will definitely be a runner once the fuel tank is swapped out. It ran strong prior to being parked. Price dropped again for comanche club before I put it on Craigslist or call the scrap guy to come haul it away. Need it gone this week to make room for a bigger toy. Would prefer for it to go to a good home. There's literally over $1000 in quality parts that goes with it. Thanks again, Dustin
