J33ps Posted March 26, 2025 Share Posted March 26, 2025 Hey Guys, I'm about to clean up some leaks under the jeep. This transfer case is leaking pretty bad. I cleaned it up when I bought the truck and as best i can tell it's coming out of the fill plug. It's also got a pinion seal leak so it's a bit hard to tell. But if my plugs are leaking how do you fix that? It's not supposed to require teflon tape but I thought it might help as it seems like NPT threads? Not sure... Link to comment Share on other sites More sharing options...
89 MJ Posted March 26, 2025 Share Posted March 26, 2025 How are the conditions of the threads on both the t-case and the plug? How tight do you have the plug? Link to comment Share on other sites More sharing options...
J33ps Posted March 26, 2025 Author Share Posted March 26, 2025 2 hours ago, 89 MJ said: How are the conditions of the threads on both the t-case and the plug? How tight do you have the plug? I haven’t removed them yet, I never installed them. I put a wrench on them initially, they’re pretty tight but I haven’t confirmed torque yet Link to comment Share on other sites More sharing options...
