1999 MJ Posted March 12, 2025 Share Posted March 12, 2025 1988 LongBed that will get a 1999 XJ 4x4 conversion. With my upcoming Comanche build, I’m hoping to get something around a 2 inch lift to perhaps a 2.5 lift, on 30 inch tires, with the Spring Under the Axle. I want to keep stuff looking factory, even though it really isn’t…. Any recommendations? I’m currently looking at the General Spring, in KC at a 1700 pound load capacity. https://www.generalspringkc.com/1986-1992-jeep-comanche-rear-leaf-spring-5-3-2-leaf-1700-lbs-capacity/?utm_source=instocknotify&utm_medium=email&utm_campaign=instocknotify Any recommendations for the front coil springs? I see Crown / Quadratec has 2 inch lift coil springs. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 14, 2025 Share Posted March 14, 2025 I’d suggest the 1280 springs unless you’re some major weight in the bed. Both springs offer the same free arch and provide basically the same lift. Link to comment Share on other sites More sharing options...
