Rockin91MJ Posted February 27 Share Posted February 27 I have been working on an issue for a while and need some help. My interior lights and marker/tail lights do not work. The fuse block under the dash has a fuse labeled INSTLMP. This fuse has power sometimes and other t8mes it does not. I have pulled the fuse box to check the wires coming into the box and they look fine and are seated properly. Where does the power for this fuse come from? Is there a junction somewhere I should check? It is an orange wire with a black tracer. Yesterday while working on it the lights just started working and worked the rest of the day. Today they did not work and the Jeep didn’t move overnight. Any ideas on where to look? Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 27 Share Posted February 27 Have you cleaned your grounds? The interior lights are on the dome lamp circuit, those are controlled by switches in the door that are known to corrode. the instrument panel lamps are on a different circuit than the front marker and tail lights. The parking lamps fuse however is your tails and front marker lights. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 27 Share Posted February 27 Also some specs about your MJ will help better, if your username is true and you have a 91, its gonna be different than most the 86-90's on here. Link to comment Share on other sites More sharing options...
Rockin91MJ Posted February 27 Author Share Posted February 27 It is a 91 MJ with a 4.0 and auto transmission. I will double check the grounds. Link to comment Share on other sites More sharing options...
