Cabz Posted April 11, 2006 Share Posted April 11, 2006 I need to replace the front shaft on my MJ badly, I have a LWB 4.0 , ba10 231. Does anyone know if a front driveshaft from an XJ with the 4.0,aw4,231 will work? The slip joint on mine is totaly worn out , I found this out after the front axle swap and lift. The damn thing is vibrating Like a $10 dollar hooker with epilepsy :D Link to comment Share on other sites More sharing options...
Burls Posted April 11, 2006 Share Posted April 11, 2006 the xj front drive shaft is the same length Link to comment Share on other sites More sharing options...
