ComancheKid99 Posted August 26, 2024 Share Posted August 26, 2024 Hello. First post here. Lurked the forums for a while now. Have an 89 Comanche 4.0 Auto 2wd with 129k miles. Owned it just barley over a year now. It's been a mostly reliable truck up until now. Never left me stranded except for a flat once. Mostly just drive it around town 30mins-1hr. Use it mainly for hauling scrap, wood and garbage runs to local dump. Doesn't wanna shift out of first few gears it seems? High RPMs accelerating at first. Once it gets going out of the first few gears it seems fine. Until you hit a complete stop it stalls out / feels like it's in neutral when first accelerating. Just doesn't wanna seem to go... Oddly though I noticed it works perfectly fine in reverse. I do have the Renix Engine Monitor (REM). Under trans info the REM doesn't read the gear it's currently in. Displays gear as " ??? ". Says solenoid 1 and 2 off. (Highly doubtful they could've both went bad at same time?). Shift point logic says off also (I'm unsure what that is even for). Could the TCU itself be bad, causing these weird trans issues? I'm no mechanic or Jeep expert. I got this truck as a project vehicle mostly to learn as I go. Also because fond memories of Dads '86 MJ when I was very young. Any advice or guidance on where I should start to address this issue would be greatly appreciated! Few things that I have done so far; -Removed and cleaned the throttle body. No difference. (Definitely needed it anyways though - had a lot of carbon build up). -Checked trans dipstick - it's seems fine. Normal color. Not low. -Refreshed ground by the oil dipstick per one of Cruisers tips. Didn't look like a bad ground. However I refreshed it anyways to no avail. Link to comment Share on other sites More sharing options...
Ωhm Posted August 26, 2024 Share Posted August 26, 2024 Check this fuse. Link to comment Share on other sites More sharing options...
ComancheKid99 Posted August 29, 2024 Author Share Posted August 29, 2024 Are there any videos or guides on how to remove the passenger dash panel? I've never done this before Link to comment Share on other sites More sharing options...
ComancheKid99 Posted August 30, 2024 Author Share Posted August 30, 2024 Managed to remove dash on passenger side. Fuse had a hairline crack on the red plastic part. I tested it read fine but replaced it anyways to no avail. Still have same issues no auto shifting. Should I look for a used TCU or check junkyard next ? Any advice would be appreciated. Link to comment Share on other sites More sharing options...
