72cut Posted July 22, 2024 Share Posted July 22, 2024 I have an 88 with 4.0 It has new radiator, water pump? Thermo, hoses, fuel pump and lines. Question 1 ( yes I'm sure this has been exhaustively covered but my other two questions prob haven't so stick with me) As stated truck has new radiator, pump and thermo So I'm running the truck for first time since these things have been installed so I know there is air in system. When truck idles the temp approaches 210 when I turn it off. Hoses get hot, fluid Still drains from reservoir after truck is turned off and air still escapes when I loosen the cap so I'm still bleeding it. Now, is 210 normal? I've never let it go beyond that so I don't know how high it will go but what is normal? Because of length of this question I'll address the other two questions in separate post Link to comment Share on other sites More sharing options...
speeding_infraction Posted July 22, 2024 Share Posted July 22, 2024 Shouldn't go past 210. That is normal, mine fluctuated between 190-210. If it goes past 210, you have some other issues. Link to comment Share on other sites More sharing options...
72cut Posted July 24, 2024 Author Share Posted July 24, 2024 Ok will start it and see how high it goes Link to comment Share on other sites More sharing options...
