RiversideMJ Posted July 4, 2024 Share Posted July 4, 2024 Hey guys, I replaced my injectors and removed the fuel line. Must’ve pulled too hard and loosened the fitting because I am now leaking gas from the fitting. I tried putting fuel resistant gasket maker (blue stuff) and nothing. Now I want to replace the hose and fitting, Dorman (800-120), but there is no disconnect on the bottom of truck. What tips/suggestions do y’all have for me? Would using a 5/16 barbed connector work if I were to cut the hose and connect with that and a couple of clamps? Thanks Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted July 4, 2024 Share Posted July 4, 2024 I had to make fuel lines for my Eagle when I put the 4.0 in that and this is what I used on the fuel rail return side. https://www.autozone.com/fuel-systems/fuel-line-repair/p/dorman-oe-solutions-5-16in-steel-body-fuel-line-connector/238632_0_0 They also make one in 3/8 size for the pressure side Link to comment Share on other sites More sharing options...
