89 MJ Posted June 18, 2024 Share Posted June 18, 2024 I recently put an extra NP231J in my Eagle. The Eagle has a different front driveshaft set up as XJs and MJs, it it requires a u bolt style u joint strap instead of the bolts like our MJs use. I also needed them for the rear because I used the Rubicon Express SYE, but that’s beside the point. The u joint straps you will need are SKF part number UJ534-10. Hopefully this helps someone in the future. Link to comment Share on other sites More sharing options...
