Brandon12946 Posted June 16 Share Posted June 16 i have a 1986 mj as of late it stopped starting i replaced the starter it was making a click sound from the relay every time i went to start it but after i replaced the starter it still does it and won't start no crank i have power everywhere my ignition feels a little lose like the key switch can move back and forth. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted June 16 Share Posted June 16 I would say that it could be the ignition switch, but I don't know what the symptoms look like in that scenario. Could be the ignition module on the steering column possibly. But most importantly-- did you check your grounds??? Double check battery ground, triple check it. Clean the connection. I had what I thought was an absolutely SOLID and clean connection on a '93 ZJ once, nope, wasn't on tight enough, even though it felt plenty tight. Link to comment Share on other sites More sharing options...
zomeizter Posted June 20 Share Posted June 20 Bypass your starter relay by bridging the two bigger terminals together, if it cranks, the relay is defective. If your truck is equipped with the big steel relay, upgrade to a Ford F150 starter relay... Link to comment Share on other sites More sharing options...
Brandon12946 Posted June 22 Author Share Posted June 22 Which part number is the Ford's Link to comment Share on other sites More sharing options...
Brandon12946 Posted June 22 Author Share Posted June 22 Grounds are fine and clean just keep getting a click clack when I try to turn her over Link to comment Share on other sites More sharing options...
