fiatslug87 Posted May 24, 2024 Share Posted May 24, 2024 THE HISTORY OF THE 4.0 BEST INJECTORS FOR RENIX The original Renix injectors made by Siemens-Deka were only “one holers”. That means the fuel was discharged through only one hole. Not the most efficient design by today’s standards. Modern injectors have at least 4 spray holes for better fuel atomization. Another issue is the original injectors were prone to leaking fuel at a seam and spraying gas all over hot manifolds. Not good!! A nice upgrade is to use Volvo injectors. The use of these injectors was pioneered by Programbo from Cherokee Forum when he suggested them to DFlintstone there. Flintstone was the guinea pig and reported excellent results. I have experienced the same results as have many others. The 746s, as they’re called, have the 4 hole design and the complete Bosch part number is 0 280 155 746. These injectors can be purchased refurbished for not much money and are a direct bolt-in. WARNING: AVOID THE CHICOM KNOCKOFF INJECTORS!!! BUY ORIGINAL BOSCH/VOLVO REFURBISHED INJECTORS HERE IN THE USA. OR, CONTACT TREVOR AT THE EMAIL BELOW AND GET THE CORRECT INJECTORS FOR YOUR APPLICATION. They are high quality, refurbished and TESTED. You’ll get flow matched injectors with the spec sheet included. Trevor.skankfootracing@gmail.com You will experience smoother idle and better throttle response. Perhaps some MPG improvement also. Link to comment Share on other sites More sharing options...
