fiatslug87 Posted May 24, 2024 Share Posted May 24, 2024 CRUISER'S MOSTLY RENIX TIPS OIL FILLER CAP MOD We all get tired of the oil film/leak on top of our 4.0 Jeep aluminum valve covers. Many times the biggest culprit is the loose fitting oil filler cap. Here’s a real easy fix: Remove the plastic oil filler cap and wrestle the original rubber gasket from it using a small pick or screwdriver. Make a duplicate of the gasket out of an old bicycle inner tube using scissors and a knife or razor blade. Install the duplicate on the cap first, and then the original over top of it. It will be a tight fit on the valve cover the first time, and may require some persuasion with a pair of pliers, but will get easier with time. Revised 1-31-2016 Link to comment Share on other sites More sharing options...
