fiatslug87 Posted May 24, 2024 Share Posted May 24, 2024 CRUISER'S MOSTLY RENIX TIPS RENIX VACUUM HARNESSES The vacuum harness that attaches to the front of the valve cover and includes the grommet/fitting, and is called the front harness, is Napa part number BK 715-1367 or is a Dorman 46003. The vacuum harness that is closest to the air cleaner, EGR etc, and is called the rear harness, is Napa part number BK 715-1366 or is a Dorman 46004. The tube from the rear of the valve cover to the intake manifold is part number BK 715-1365 or Dorman 46005 and comes with the valve cover grommet. The Throttle Body to MAP hose is no longer available. Click HERE to access a fix for that. Revised 2-6-2016 Link to comment Share on other sites More sharing options...
