KANTANKRUS Posted May 22 Share Posted May 22 Can this be replaced, or pulled apart and cleaned? Please advise... Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted May 24 Share Posted May 24 I take it you are specifically referring to the coiled wire portion, yes? I recently did a bored throttle body on my Renix and saw that mine was actually quite filthy with dirt and micro bunnies. So I took a try old toothbrush I've had since 1995 and got on there. I don't think it mattered but it was driving me crazy to look at while adjusting the TPS. As for taking it apart? I don't know if I would go that far. But that's just me. Link to comment Share on other sites More sharing options...
KANTANKRUS Posted May 25 Author Share Posted May 25 18 hours ago, Spinnakerblue89 said: I take it you are specifically referring to the coiled wire portion, yes? I recently did a bored throttle body on my Renix and saw that mine was actually quite filthy with dirt and micro bunnies. So I took a try old toothbrush I've had since 1995 and got on there. I don't think it mattered but it was driving me crazy to look at while adjusting the TPS. As for taking it apart? I don't know if I would go that far. But that's just me. Yes, I just bet mine is as bad as yours was, with filth... I am going to try to resurrect it with some sort of brush! Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted May 25 Share Posted May 25 I imagine that if it's sticking due to corrosion, there's not much you can do aside from replacing it or the throttle body. But if it's only dirt, a good brush and maybe some sort of cleaner would help. Obviously be careful about what gets into the throttle body itself. Link to comment Share on other sites More sharing options...
