rangrbob Posted January 4, 2008 Share Posted January 4, 2008 I cannot seem to find the sending unit on my 2.5l engine. I'm working on a gauge cluster swap and still need to hook up the oil pressure gauge. Can one of you point me in the right direction. Also, the cluster I'm using was out of a 4.0, and I was able to adjust the tach, but when I first turned on the ignition, the gas gauge needle buried itself past full. I moved it beyond empty by hand then turned on the ignition again and it seemed to work. Is there a trick to get it to read correctly. Thanks Link to comment Share on other sites More sharing options...
tjbliley Posted January 4, 2008 Share Posted January 4, 2008 Oil pressure sending unit is under the no 1 cyl at the bottom of the block Pass side. Right next to the alt. Link to comment Share on other sites More sharing options...
rangrbob Posted January 4, 2008 Author Share Posted January 4, 2008 Thank you sir. Link to comment Share on other sites More sharing options...
