2.8 Coil brackets
Hey all! Never posted an update to my last issue, but I got the electrical issue sorted (ended up being a bad ground strap in the engine bay that did it)
After a week or so, ignition coil appears to have gone bad... She must still be on her first coil, because it seems to be *riveted* in on the bracket?! I just want to make sure that that's correct, and that I'm not missing an easy replacement method before I drill the rivets out (which will definitely be a pain around all those vacuum lines)
1986, 2.8 V6
Thanks!
