column shift aw4 linkage broken
  • Pete M changed the title to column shift aw4 linkage broken
answer: less screwed than I thought.  the shorter one is the column shift, the longer one is from the 4wd trans that's eventually going into the truck.  ends are close enough to be the same.  just gotta figure out a path for the long cable and then somehow plug up the firewall.
