Vacuum/EPA
Hi all, in the midst of replacing my vacuum harness I have discovered that with the previous owner adding their own cold air intake they cut out a lot of the connection points. Is it ok to just plug these hoses or do I need to find a way to route them to something? And is there a list anywhere of stuff that can just be deleted/plugged without harming the motor or performance in any way?
18 hours ago, ghetdjc320 said:
Could you post some pictures of what you’re finding? Is this for your 89 MJ in your sig?
It is, I actually ended up figuring it out last night! Just took a lot of tracing and youtube.
