seeuy2k Posted September 12, 2023 Share Posted September 12, 2023 What are people using for a replacement fuel pump ? I thought I found a Bosch 69302 but later got an e-mail from the company they were out of stock. Any recommendations on what pump to use ? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 14, 2023 Share Posted September 14, 2023 The carter or airtex work fine but don’t last very long from what I have seen. There area a few of us who have adapted other pumps like the Deatshwerks DW200 but it takes some modifications to fit. Here is rather simple way that I installed mine. Had to use the old rubber straps from the airtex pump along with a different pump strainer. At some point I may remove the upper pump retainer but for now it acts as a nice hose and wiring guide Link to comment Share on other sites More sharing options...
seeuy2k Posted September 15, 2023 Author Share Posted September 15, 2023 Thank you for the reply. I ended up ordering the Carter P90011. I have heard the Airtex did not have a very good reputation so went with Carter. If this one goes out I will try the DW200. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 16, 2023 Share Posted September 16, 2023 10 hours ago, seeuy2k said: Thank you for the reply. I ended up ordering the Carter P90011. I have heard the Airtex did not have a very good reputation so went with Carter. If this one goes out I will try the DW200. I had also heard the same thing but the airtex lasted the same as the carter for me. Pretty sure they are made by the same manufacturer Link to comment Share on other sites More sharing options...
