1J7FJ26L3LL244472
wncmanche
1990 Jeep Comanche SportTruck 180k
4.0 / AX15 / 4WD 231 / D30 / D35 / Short Bed / Colorado Red
Build date: 4-90
Current Location: Western NC, Watauga County
Status: Running and driving well for the most part. Bought it from Inman, SC @179k and drove it ~3 hours back without issue. Steering feels pretty loose/ floaty but drives great for the most part. Intermittent idle climbing in RPMs - 1.5k to 2k at stoplights has been fun. PO said it was a vacuum leak he couldn’t track down.
Notes: Found this one for a reasonable price - the bones are rust free, minus both rockers and on rear fender. It was the 4.0 / Manual / 4WD / Short Bed configuration i was searching for to replace my rusted out 2dr XJ. Grey interior in decent shape, bench seat, removed headliner as it was sagging and ripped. Manual windows, AC, radio delete, lol.
I’m very happy with how it has held up so far. It does seem to have less “pep” then my 1996 XJ on 33s, maybe the engine is a little worn out or just the difference in non- HO 4.0. I’ve noticed somewhat low oil pressure, not usually going above 40psi.
Current owner: Me
Work done so far:
- Swapped gauges to have full gauges, found a full gauge cluster on eBay within 500miles of the original cluster.
- Removed the rear bumper, it was too rusty.
- P.O. did the h4 headlight upgrade
- Swapped in functioning side mirrors
Plans:
- Really would like to fix rockers, fenders, dings, dents, and get it repainted.
- Found a nice set of turbines w/ center caps that will go with new tires
- Have a nice drivers side vent window waiting to go in to replace the current one. It doesn’t close right and wind noise is getting annoying.
- Jeep Cables waiting to go in
- Cruiser 54 Tips will be a completed soon. Going to clean up all the grounds when battery cables go in. Noticed oil on the air filter, will do tip 26(I think) to combat that.
Itching not to build it. I want to keep it stock, for now at least. If you have any tips for a renix first timer, please let me know.
*X1 TRIM STYLE X1 - CLOTH BENCH
-SA Charcoal
167 Zone 67-Charlotte
1AA U.S. Dealer Retail
5KK First American Title Insurance CO.
ALA SE DECOR GROUP
ALK ITALIA PACKAGE
APA MONOTONE PAINT
BAY 105 AMP ALTERNATOR
BCY 475 AMP BATTERY
BGA POWER FRONT DISC/REAR DRUM BRAKES
CBA STRAIGHT BACK BENCH SEAT
CKA CARPETS - FLOOR AND CARGO AREA
CSR PASSENGER ASSIST HANDLES
CUM MINI FLOOR CONSOLE
DBB ALL MANUAL TRANSMISSIONS
DDQ 5-SPEED MANUAL TRANSMISSION
DHN COMMAND-TRAC PART TIME 4WD SYSTEM
DJH 230MM FRONT AXLE
DMM 3.07 REAR AXLE RATIO
DRJ DANA M235 WIDE REAR AXLE
ERB ENGINE - 4.0L I6 MPI GAS
GAC TINTED GLASS WINDOWS
GBB TINTED WINDSHIELD GLASS
GCB FRONT DOOR TINTED GLASS
GEC FRONT LEFT SIDE SLIDING WINDOW
GNA REAR VIEW DAY/NIGHT MIRROR
GRZ LEFT REMOTE MIRROR
GSZ RIGHT REMOTE CONTROL MIRROR
GTZ MANUAL REMOTE MIRRORS
HAA AIR CONDITIONING
JAZ DO NOT USE - SEE JP, KA CLASSES
JCA 85 MPH PRIMARY SPEEDOMETER
JJA CIGAR LIGHTER
K3Z STRIPE/BADGE/MOLDING/COLOR
KDA STRIPE/BADGE/MOLDING/COLOR
LAP SHIFT INDICATOR WARNING LAMP
LBC GLOVE BOX LAMP
LCJ DOME/READING LAMP B-PILLAR
LMA HALOGEN HEADLAMPS
MB1 Black Front Bumper
MBJ BLACK POWDER COATED FRONT BUMPER
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z84 Right Front Spring Group XIII
Build date 4/25/90
Body code JL61
Sold by ALLISON'S INC, SYLVA NC
