FigurativeGarbage Posted October 22, 2024 Author Share Posted October 22, 2024 On 4/12/2023 at 11:44 AM, Greentoy said: We're in the middle of this swap in an 85 XJ. Was your modification to the oil pan absolutely necessary? I ask because our plan is to lift the xj about 3 " and I wonder if that will give adequate clearance for the pan. Thoughts? Sorry, I haven't logged in to CC in a long time. In hindsight, I suspect the unmodified pan may have had enough clearance without modifications. I'll see if I can get you a pic at some point. For now, I'm going to document this project on the projects thread as eaglescout suggested. Link to comment Share on other sites More sharing options...
FigurativeGarbage Posted October 23, 2024 Author Share Posted October 23, 2024 On 4/12/2023 at 11:44 AM, Greentoy said: We're in the middle of this swap in an 85 XJ. Was your modification to the oil pan absolutely necessary? I ask because our plan is to lift the xj about 3 " and I wonder if that will give adequate clearance for the pan. Thoughts? Looking at the clearance, I think modifying the pan was unnecessary. Maybe other the other builds noted the issue had different set ups. See the attached photos; one may appear upside down, but you can see there's a great deal of clearance. In hindsight, I would have installed the engine without a pan and check the clearances after. Link to comment Share on other sites More sharing options...
