Help! Sway bar disconnect bolt?
If those are the JKS discos that upper U bracket has a threaded hole that the bolt tightens into, it's not just a bolt/nut that holds it on. Take a look at that uppper U bracket to see if there are threads, if so remove the bracket and straighten it out with press/hammer/anvil/crescent wrench. Then use that bracket to figure out what size/thread bolt you need.
