door lock failure
has locks only, no power windows
the door locks on my truck no longer work. there is power to the switch, and the switch seems to function when I use a test light. however, power does not get to the lock cylinders. ground seems fine, I redid the ground just to check. are there any common points for failure?
I can't find any TSB's on alldata for it, and the wiring diagrams don't really get as in-depth as I need
-thanks
dude something goes wrong with the 3800 almost every damnable day haha.
atleast its fixable most of the time.
lol,
not anymore.
today I put in a new rear pinion seal, topped off the dif. fluid, topped off the t-case fluid, rebled the clutch, installed the single key entry/ignition off a 94 xj (matched the new steering column), installed better vent wing windows, cleaned all glass.
the frames completely fixed, the intake is relocated higher, and the only darned thing that it could possibly need right now is to have the dent pulled, and the subwoofer replaced (cracked). I'd say she's doin pretty good.
heck, I even have a cargo light to install now :brows: jamminz.gif
