1990 Comanche base
2.5l / 2wd / short bed / 68,000 miles
5-90
Northeast Georgia
The jeep currently does not have an engine or trans. Bought it not running and sold off the 2.5l/2wd stuff to make a little money back. I also found a set of 31s for cheap so I threw them on there. My plans for now are to do some body work and insulate/ rust proof it while I look for a 97+ 4.0 4wd donor Cherokee for a swap.
According to carfax she has had 7 owners all within a 50 mile radius of me.
*X2 TRIM STYLE X2 - VINYL BENCH
-SA Charcoal
135 Zone 35-Washington
1AA U.S. Dealer Retail
ALA SE DECOR GROUP
APA MONOTONE PAINT
BAQ 61 AMP ALTERNATOR
BCX Maint. Free Battery
BGA POWER FRONT DISC/REAR DRUM BRAKES
CBA STRAIGHT BACK BENCH SEAT
CKJ BLACK VINYL FLOOR COVERING
CSR PASSENGER ASSIST HANDLES
CUM MINI FLOOR CONSOLE
DBB ALL MANUAL TRANSMISSIONS
DCK 4SPD MANUAL TRANS
DMD 3.55 REAR AXLE RATIO
DRJ DANA 35 REAR AXLE
EPD ENGINE - 2.5L I4 TBI GAS
GAC TINTED GLASS WINDOWS
GBB TINTED WINDSHIELD GLASS
GCB FRONT DOOR TINTED GLASS
GEH FIXED DOOR VENT GLASS
GNA REAR VIEW DAY/NIGHT MIRROR
GRV LEFT MANUAL MIRROR
GUA OPEN
HCD DO NOT USE - SEE HCA
JAZ DO NOT USE - SEE JP, KA CLASSES
JCA 85 MPH PRIMARY SPEEDOMETER
K3Z STRIPE/BADGE/MOLDING/COLOR
KDB STRIPE/BADGE/MOLDING
LAP SHIFT INDICATOR WARNING LAMP
LBC GLOVE BOX LAMP
LMA HALOGEN HEADLAMPS
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SAA Manual Steering
SCB Steering Whl
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z56 Left Front Spring Group Vi
Z75 Right Front Spring Group V
Build date 5/6/90
Body code TL61
Sold by WILLIAM CLARKE JEEP-EAGLE, FREDERICKSBURG VA
