Htchevyii Posted September 12, 2022 Share Posted September 12, 2022 Not sure how many of you are running the long discontinued Spectre cowl intake, but I found an easy solution for the hard to access oil cap. I found a NOS one on eBay a few years ago, but tired of pulling the whole thing off to add oil. Speedway sells a kit to add an oil fill cap. It's a little tedious grinding away the fins to make a smooth surface, but worked pretty good. https://www.speedwaymotors.com/Valve-Cover-Oil-Filler-Cap,48973.html VID_20220909_124110675.mp4 Link to comment Share on other sites More sharing options...
Muncher Posted September 12, 2022 Share Posted September 12, 2022 I use to have one actually. I just used a skinny funnel and could access the stock one without removing the air filter. Link to comment Share on other sites More sharing options...
