1J7FJ26L8LL101789
DaltonScott
Year, Make, Model :
1990 Jeep Commanche PU
Manual swapped 4x4
long bed
Engine: 4.0L I6 / Trans: unknown, auto-manual swap/ Transfercase: unknown / Front axle: unknown / Rear axle: unknown / Wheelbase: LWB
Build date: (its on the driverside door sticker, in the form of month and year)
Current Location: Gillette, wyoming
Status: currently used as a daily driver, my second commanche. mostly road legal minus turn signals. Needs alot of work, paint, floorpans, brakes, front passenger u-joint, rear diff gasket, head gasket oil leak fixed, most of the dash & interior etc.. as well as my plans for upgrades
Notes: According to a vin lookup was built automatic, now 5-speed manual. Red in color for now. I believe the motor has been rebuilt previously. Custom tailgate not made by me. I installed 4-port injectors given to me by PO
Current owner: my Name is Dalton Knutsen, I'm 26 years old and i purchased this one from the owner of an auto glass shop in town for $675 about 7 months ago. This is my second ownership. When i boughht the truck it had been sitting, barely ran due to the IAC and plugged exaust. The only working light on the truck was the passenger high beams. I have since troubleshot and replaced the exterior lighting to be funcional minus turn signals, and the truck runs great aside from i what believe is a slipping clutch and multiple oil leaks. She needs some love, but we're getting there. Ya'll are welcome to find and message me on the jeep commanche lovers and enthusiasts page. Looking forward to learning as much as i can!
*X2 TRIM STYLE X2 - VINYL BENCH
-SA Charcoal
174 Zone 74-Denver
1AA U.S. Dealer Retail
ALA SE Decor Group
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ Dana 35 Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KWX
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAF High Altitude Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RA8 Delete Radio
SBA Power Steering
SCB Steering Whl
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z65 Left Front Group XIV
Z84 Right Front Spring Group XIII
Build date 7/19/89
Body code JL62
Sold by POLLARD JEEP OF BOULDER,  Boulder CO
