yungupgrade Posted August 19, 2022 Share Posted August 19, 2022 This came off of the parking brake cable which went to the cab. There was no nut that came with the replacement. I have no idea what the stopper thing is behind the washer. Is this just something I need to buy at a hardware store? Link to comment Share on other sites More sharing options...
Dandxj Posted August 20, 2022 Share Posted August 20, 2022 It is the adjustment nut for the parking brake equalizer. I believe it is one piece. I am also looking for one as mine was so rusted I had to cut the cable to remove it. I'll probably just use a washer and nut if I can not find one. The "nub" on the left of the washer fits into the hole in the equalizer to keep it aligned. Let me know if you find something. Thanks Link to comment Share on other sites More sharing options...
yungupgrade Posted August 20, 2022 Author Share Posted August 20, 2022 https://www.quadratec.com/p/crown-automotive/parking-brake-adjuster-wrangler-tj-and-98-grand-cherokee-zj It looks like replacements just use a nut and bolt so it should suffice. Just gotta measure the bolt, would be easier if I had calipers Link to comment Share on other sites More sharing options...
