RandysMJ Posted November 30, 2007 Posted November 30, 2007 Does anybody have the part numbers for the seals that are needed when putting in a 1 piece pass side front axle? Are the seals the only thing needed? Thanks
Twisty Posted November 30, 2007 Posted November 30, 2007 I am assuming you are talking about a D30 (your profile says D44s). Anyways, Randy's Ring and Pinion has the conversion kit for this job. I just knocked out the seal at the disco side, and put a normal axle seal in there. Then I took some steel wool, and polished the axle shaft right where the seal would be sealing. No leaks to date...so I assume its working.
RandysMJ Posted November 30, 2007 Author Posted November 30, 2007 Yeah i mean't for a D30. A friend of mine is wanting to do this. I remember seeing someone on here that had done it. They got the seals from NAPA i think. They posted the part numbers. But i can't find the post now.
Twisty Posted November 30, 2007 Posted November 30, 2007 Supposedly, there is a CJ axle seal that will work. I don't know the number but I DO know that I saw it on NAXJA. EDIT. I did a quick search, and came up with this... http://www.naxja.org/forum/showthread.p ... disconnect And I guess the guy who knows what exact seal to use is ChuckD. Search for his name as well.
jeepthing07 Posted December 1, 2007 Posted December 1, 2007 I'm going to be putting a 1 piece shaft in my YJ. i was reading around about it awhile ago and they say that not all the housings are the same. and there are 3 possiable different seals depending what year the axle housing was made in. i havent messed with mine yet so i don't know, but might want to keep that in mind.
MJ20 Posted December 1, 2007 Posted December 1, 2007 Here’s a good write up with part #’s on the seals and upgrading to larger axle joints. http://www.madxj.com/MADXJ/technical/te ... dSeals.htm
