devere Posted February 1, 2022 Posted February 1, 2022 VIN : 1JTHA6611GT050724 Country : United States Manufacturer : Jeep Corporation Vehicle Type : Truck Engine : AMC 4 Cyl. 2.46 Liter, 150 CID, Domestic Powertrain : 3 Speed, Automatic Transmission, Column Shift, 2 WD Line (Body Type) : Comanche Truck, 2 WD, 7 ft Box Model and Gross Vehicle Weight : Cherokee Base Model, 4001#-5000# GVW * Comanche Custom Model, Standard Payload [1815/2268 Kg] Check Digit : 1 Year : 1986 Plant Location : Toledo, Ohio, USA Sequential Serial Number : 050724 Check Digit Test : VIN valide currently in Ithaca Michigan, i own it Devere Martyn, Black interior and exterior, currently getting body restored was bought from person in st johns mi. unsure of build date door tag painted over will upload pics when finished
eaglescout526 Posted February 3, 2022 Posted February 3, 2022 *ZZ TRIM STYLE ZZ - BUCKET SEAT -ZZ CGX Head Restraints-Outboard Seating, RR DGZ Transmission- 3-Spd. Automatic EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) Build date 10/4/85 Body code TL62
