Switch Panel for the right of steering column position
This switch panel allows you to add two switches to the stock panel position to the right of the steering column.
Eliminate mislabeled stock switch positions, and center your switches.
Or add two switches to the dash replacing your blockoff plate or one switch panel.
This is a new panel made of strong, temperature resistant ABS plastic.
It fits two Carling rocker type switches (Carling, Contura).
The finish is raw ABS plastic that can be painted as needed.
Switches not included
https://www.ebay.com/itm/284482961005
COMANCHECLUB coupon code for 10% off.
Panelwhite.jpg.9c685af27ca1cc1892a8b32ccc40f4ed.jpgfarview.jpg.e1312aabf17203fbea0b33c578ebc794.jpg
  • m2bandit changed the title to Switch Panel for the right of steering column position
  • 4 weeks later...
