1J7FJ26L2LL177962
Burgundybestcolor
Body: JL61
Build Date: 11/14/89
Selling Dealer: PERFORMANCE LAURENTIDES INC.
MONT-LAURIER, QC (CAN)
*X1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE ALA
CBAP Straight Back Bench Seat CKJP Black Vinyl Floor Covering DBBC All Manual Transmissions
DDQ 5-Speed Manual Transmission ERB 4.0L I6 MPI Engine GRZP Left Remote Mirror
GSZP Right Remote Control Mirror PW7 Bright White Clear Coat SBAA Power Steering
TAAC All Tires TNCA P195/65R15 BSW AS Touring Tires WLYC All Steel Wheels
YBA 30.2 Liters Of Fuel YGAA Without Billable Fuel Z01P Rear Spring Group I
Z65P Left Front Group XIV Z84P Right Front Spring Group XIII 3N8A Drive Away Program Tracking
3PWA 5YR/60,000 - Added Care 4EA Sold Vehicle
APAS Monotone Paint BAQS 115 Amp Alternator BCXS Maint. Free Battery
BGAS Power Front Disc/Rear Drum Brakes CSRS Passenger Assist Handles CUMS Mini Floor Console
DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio
DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror
GTZS Manual Remote Mirrors HCDS Do Not Use - See HCA JAZS DO NOT USE - See JP, KA classes
JDBS 180 KPH Primary Speedometer KDDS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR
LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting
LMAS Halogen Headlamps LMKS   MB1S Black Front Bumper
MDAS Front License Plate Bracket MFFS Black Grille MHBS 35 Tire Body Color Fender Flares
MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares
NAAS Federal Emissions NBKS EVAP Control System NF2S 18 Gallon Fuel Tank
NHKS Engine Block Heater QW7S Bright White Clear Coat RA8S Delete Radio
SCBS Steering Whl SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers
TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels
WMCS Open XBSS Pickup Box YACS Build To Canada Mkt. Specifications
Z5AS GVW/Payload Rating 1ABS Canada Dealer Retail 122S Zone 22-Canada-Quebec
