schardein Posted May 29, 2021 Share Posted May 29, 2021 This OEM shift boot looks great, but does have some flaws. A small tear inside the fold on the driver side, I don't think it shows during normal use. Also, a small tear on the inside which I don't think affects anything, and the plastic insert has a crack. The crack normally isn't noticeable, I twisted it open for the pic. I think it will still hold fine in the console- it was holding fine when I removed it. If your boot is trashed but the insert is good, it could be transferred to this boot. I've sold a couple of these in the past in the $25 range, how about $10 + shipping? It weighs 9 ounces (unboxed) so should be able to go USPS 1st class, from 65570. Link to comment Share on other sites More sharing options...
Archived
