youngfred Posted March 1, 2021 Posted March 1, 2021 ... Had a couple Cup Holders laying around, so I started cutting and epoxying on one, of-em. Had a piece of plastic divider from a parts-sorter that I used to support the front side, which is pretty flimsy because of the e-brake cutout for XJ's. Moved around a lot, when using the Mirror Switch. That plastic piece really strengthened that front-side. I epoxied the piece then used Black bolt/nut on the four corners. I have another new cup holder that I plan to use if this one holds up. I am going to see how this works. youngfred
youngfred Posted March 2, 2021 Author Posted March 2, 2021 1 hour ago, Tex06 said: What year XJ is that console out of? ... That's the cheap $13 pop cup holder. I had the three pigtails for the Power Mirrors (switch, both mirror- harness side) so I built a harness for the power mirrors. I had to decide whether to mount the power mirror switch on the console or on the cup holder. The cup holder was cheap, so I started cutting on the cup holder to mount the switch and to reinforce that front panel. youngfred
youngfred Posted March 2, 2021 Author Posted March 2, 2021 ... The Power Door Panels and the Dash Panel came out of a 1995 XJ - Country. * I took the photo, as Dash Panel was going in. I still needed to install the screw above the cigar lighter in order to flatten the panel out. youngfred
